marty1964
Jul 25, 2021Follower
MacBook Pro keeps disconnecting to wifi at random intervals
my model RBR50 keeps disconnecting when accessed with my macbook pro.It happens frequently but only with my laptop and ipad.Not with my other android devices.I tried factory resetting but the problem...
Jul 26, 2021Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Do you have Armor or Circle enabled?
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
