Gwolf
Jun 09, 2020Aspirant
Macbook sticking on 2.4ghz and not moving to 5ghz on Orbi RBR50
My Macbook Pro 13" is unable to connect to the 5Ghz network as it stays on the 2.4Ghz. My speeds on the Macbook are in the 5-14 Mbps download and go as low as 1Mpbs during the day. My Samsung S10 pho...
Gwolf
What Firmware version is currently loaded? (v2.5.1.16)
What OSX Version are you using on the MBP? (Version 10.15.5)
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? (AT&T Uverse NG with fiber into the house. 1Gbps is what I am paying for. )
What is the distance between the router and satellite(s)? (I get blue lights so it appears to be close enough to. The Main RBR50 is about 6 feet from the cable model connected via ethernet.)
What channels are you using? (Switched the 2.4Ghz to channel 1 and left 5Ghz at 48. Just did a speed test and download 150Mbps and upload 30 Mpbs)
Any Wifi Neighbors near by? If so, how many? (1 neighbors wifi which is 2 bars on wifi)
I noticed when I changed Preamble to short on 2.4Ghz and 5Ghz, my speed drastically droppped. The images is a screen shot of my advanced settings. Only issues now is upload speed should be higher.
What about Router Mode vs AP Mode? Would that have any impact on my speed? Right now it is in Router Mode.
Appreciate the help.
Jun 09, 2020Guru - Experienced User
Gwolf wrote:What Firmware version is currently loaded? (v2.5.1.16)
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? (AT&T Uverse NG with fiber into the house. 1Gbps is what I am paying for. ) If this has a built in router, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.I would try option #3...
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
What is the distance between the router and satellite(s)? (I get blue lights so it appears to be close enough to. The Main RBR50 is about 6 feet from the cable model connected via ethernet.) Ensure the modems wifi is fully disabled.
What channels are you using? (Switched the 2.4Ghz to channel 1 and left 5Ghz at 48. Just did a speed test and download 150Mbps and upload 30 Mpbs) So is this better? Is the mac book connected at 5Ghz?
I noticed when I changed Preamble to short on 2.4Ghz and 5Ghz, my speed drastically droppped. The images is a screen shot of my advanced settings. Only issues now is upload speed should be higher. Change back to long preamble.
AP mode would be recommended since you have a ATT modem/router that can't be fully bridged.
