pup0975
Mar 02, 2017Star
Macbook takes 15-20 seconds to start connecting to internet after turning on
Just got a new Orbi 2 satellite system. When I turn on my Macbook Pro, the wifi is connected but when opening webpages on my browser, it take about 15-20 seconds before it loads any pages. Once on, t...
msickles
Mar 02, 2017Tutor
Here is a quick recommendation:
Change your DNS servers to either Google DNS or OpenDNS (8.8.8.8;8.8.4.4 -- 208.67.222.222;208.67.220.220).
Do you still have the latency issue?
Also, do you have iPv6 enabled--or are you only native IPv4 on the Orbi?
.mws.
pup0975
Mar 02, 2017Star
I already had my DNS changed to one that was faster than my ISP (and Google's DNS) using an open DNS tester. My IPv6 was disabled. You think it would be faster with IPv6 disabled or enabled? If I should enable it, should I just use "Auto Detect"?
- msicklesMar 03, 2017Tutor
Does this happen with anything other than MacBook?
If it is only MBP, try resetting the network profile.
.mws.
