DavidTS
Sep 11, 2020Aspirant
Macbook won't connect to RB50 anymore
Macbookpro will not connnect after RB50 firmaware update. Will connect to RB50 satellite. All other devices (apple or otherwise) are fine on either
Sep 11, 2020Guru - Experienced User
have you tried forgetting the network on the mac?
DavidTS
yes. many times
- plemansSep 11, 2020Guru - Experienced User
Which firmware did you install?
Anytime there's an issue after updating firmware, a reasonable first step is factory resetting and reinstalling. Have you tried that?
- DavidTSSep 11, 2020AspirantHi. Will try that next. Kinda bummed bc it was working so nicely. Thx for your suggestions
