DavidTS
Sep 11, 2020Aspirant
Macbook won't connect to RB50 anymore
Macbookpro will not connnect after RB50 firmaware update. Will connect to RB50 satellite. All other devices (apple or otherwise) are fine on either
Mstrbig
Sep 11, 2020Master
DavidTS wrote:Macbookpro will not connnect after RB50 firmaware update. Will connect to RB50 satellite. All other devices (apple or otherwise) are fine on either
Logically speaking if all other devices don't have an issue and your Macbook does, the problem lies with the Macbook.
Maybe this article will help:
DavidTS
Hmmmmm. Connects fine to phone. And satellite RB50. Soooo your logic isnt well logical but thanks for your input
- MstrbigSep 11, 2020Master
DavidTS wrote:
Hmmmmm. Connects fine to phone. And satellite RB50. Soooo your logic isnt well logical but thanks for your inputHmmmmm.. My logc was based on your minimal amount of information. I took it as you had no internet connection on the Macbook. But again, if all other devices have no issues and your 1 device does, the problem lies with the device that is having a connection issue.
The link I posted is available because Apple is well aware of the network issues Macbooks are having with several branded routers. Some users have had to resort to purchasing a USB WIFI dongle.
