DavidTS
Sep 11, 2020Aspirant
Macbook won't connect to RB50 anymore
Macbookpro will not connnect after RB50 firmaware update. Will connect to RB50 satellite. All other devices (apple or otherwise) are fine on either
DavidTS
Hmmmmm. Connects fine to phone. And satellite RB50. Soooo your logic isnt well logical but thanks for your input
Mstrbig
Sep 11, 2020Master
Hmmmmm.. My logc was based on your minimal amount of information. I took it as you had no internet connection on the Macbook. But again, if all other devices have no issues and your 1 device does, the problem lies with the device that is having a connection issue.
The link I posted is available because Apple is well aware of the network issues Macbooks are having with several branded routers. Some users have had to resort to purchasing a USB WIFI dongle.
