aof85
Apr 01, 2018Follower
Magenta light on RBS50 - Instability increasing
After about 4 months of realtive stability, my RBS50 continues to lose connectivity from the RBR50 located ony 30' away through wood framing. I will reset it, it will be BLUE for a while, and then t...
Retired_Member
Apr 01, 2018when is this "Beta FW " going to be ready for prime time?
Apr 01, 2018Guru - Experienced User
Don't know. it maybe still in flux and in development so there maybe a new version seen upon official realease.
Beta is working well for me. 40ft distance between my router and 1 satellite. 3 wooden walls inbetween.
