maverikv
Dec 12, 2017Aspirant
Magenta Light on Router, no Internet Many times a Day
I've upgraded to the latest firmware and it keeps happening. Constantly having to reset my router. Turned off Daisy chain topology and uPNP, still happening. How can a $400 router be this bad?
Retired_Member
Dec 12, 2017Magenta usually means your SAT is too far from the router.
Whar firmware on you on?
Did you upgrade it manually?
- maverikvDec 12, 2017AspirantWhy would that take my whole internet down?
- Retired_MemberDec 12, 2017
The firmware you downloaded is not ready for prime time?
- maverikvDec 12, 2017AspirantIt was happening on my old firmware too though, that's why I upgraded
- D808Dec 12, 2017Guide
I'm having a similar issue on with my orbi. I thought it was due to my Google Home, though after posting here another google home user countered with their google home/orbi not having any issues.
I do have a question about your issue:
1.When you see the Magenta light come on is it the satellite or the main router that is showing the Magenta light?
2.When you notice the Magenta light do all of your wired and wireless devices lose internet connection?
3. On your wireless devices, when you lose internet connection, does the orbi ssid still show on your devices or does it disappear?
If you answered yes to all three, I think your orbi is rebooting and when you see the magenta light it is actually coming back online.
