SherlockOhms
Sep 18, 2019Aspirant
Magenta Ring' displayed every 10 minutes or so since 2.3.5.30 update
Running 1 RBR50 with v2.3.5.30 and 2 satellites. App is v2.4.5.17 - Wifi network within the house is fine, but the router drops its connection to the cable modem every 10 minutes or so - Orbi App ...
CrimpOn
Sep 18, 2019Guru - Experienced User
Is this magenta ring light "solid" or does it "pulse"?
Netgear's web site of Orbi color codes a pulsing magenta ring on the router indicates a problem with the internet connection.
Are you able to connect to the Orbi router using a web browser? It would be useful to know what the Orbi web interface says about the internet connection. On the Advanced Tab home page, click on Connection Status. That will tell how long the DHCP lease was originally and how much time remains on it. I would hope that if the Orbi actually "loses" the internet connection, that the most recent lease time would match the behavior you are seeing.
SherlockOhms
Sep 19, 2019Aspirant
It’s solid
Not at home at the moment, and the Orbi is inaccessible remotely so I’ll ya e to wait until I’m home to try and connect to it
