jmd49er
Jun 16, 2020Aspirant
Magenta router
My internet works great with high speeds but the router led is magenta. What does it mean?
jmd49er
Jun 27, 2020Aspirant
Firmware v2.3.5.30
Google Fiber gfrf200
Jun 28, 2020Guru - Experienced User
Your ISP modem seems to have a built in router already.
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- JlargeNov 12, 2020AspirantI solved this by switching the network cable from the ethernet to the internet port and recycling the power.
