jmd49er
Jun 17, 2020Aspirant
Magenta router
My internet works great with high speeds but the router led is magenta. What does it mean?
Jun 28, 2020Guru - Experienced User
Your ISP modem seems to have a built in router already.
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Jlarge
Nov 13, 2020Aspirant
I solved this by switching the network cable from the ethernet to the internet port and recycling the power.
