Tallrandal
Feb 21, 2019Guide
Main RBR50 Router
I currently have the following setup:
RBK50 AC3000 Wi-Fi System:
RBR50 Router
2x RBS50 (One running Wireless the other is wired via backhaul CAT 6 to garage) I had purchased second RBS50 from ...
Tallrandal
Feb 21, 2019Guide
Furrye38,
I appreciate the response. I am curretnly running new devices that can handle the 600 Mbps on wifi as I can achieve the speeds on my RBS50 that is using wired backhaul. I can also achive 500 to 600 at work where the network is enterprise level.
As for turning OFF all the satellites and runnning just the RBR50, I have done this and it still gets the same speeds. I have also gone as far as shutting off almost all the devices accessing that node.
If I tried disabling all and a mixed bag of the beamforming, MIMO Fast Roaming. Beamforming obvioulsy decreases the speeds. Outside of that nothing changes.
Feb 21, 2019Guru - Experienced User
Try a factory rest on the RBR and setup from scratch. Don't enable QoS, traffic meter or Access controls. Test the wifi immediately after setting it up. If speed doesn't change, possible the RBR is fautly.
- TallrandalFeb 21, 2019Guide
As I had mentioned, I have done 4 resets. No Speedtest, traffice meter or access controls were set. Same results.
- FURRYe38Feb 21, 2019Guru - Experienced User
I would make contact with NG support about this.
