Tallrandal
Feb 21, 2019Guide
Main RBR50 Router
I currently have the following setup:
RBK50 AC3000 Wi-Fi System:
RBR50 Router
2x RBS50 (One running Wireless the other is wired via backhaul CAT 6 to garage) I had purchased second RBS50 from ...
Tallrandal
Feb 21, 2019Guide
Both satellites are connected via 5 GHz. I have tried every channel for both 5 and 2.4 GHz. Some 5 GHz channels reduce speeds while other stay in the 200 range.
Feb 22, 2019Guru - Experienced User
I think this is a HW issue at the router. Hope NG support and offer you something. Ask for an RMA.
