gjoynerjr
Jul 12, 2021Aspirant
Main router appears to be dead; no lights on top
Hello everyone, I tried to turn on my Netgear Orbi RBR50 router after a move, but it seems like it may have died at some point during. Upon being plugged in the ring of light on the top of the ro...
Jul 12, 2021Guru - Experienced User
Try a differnt power supply? Make sure its the same voltage and amps as seen on the current adapter.
- gjoynerjrJul 13, 2021Aspirant
I only ever use the stock power supplies, and when double checking both the router and satellite use the same power supply, so accidentally swapping them doesn't seem to be the issue.
