gjoynerjr
Jul 12, 2021Aspirant
Main router appears to be dead; no lights on top
Hello everyone, I tried to turn on my Netgear Orbi RBR50 router after a move, but it seems like it may have died at some point during. Upon being plugged in the ring of light on the top of the ro...
CrimpOn
Jul 13, 2021Guru - Experienced User
gjoynerjr wrote:The power light on the back next to the power button does illuminate.
The power LED comes on GREEN? When you hold in the reset button (tiny hole) for 10-15 seconds, does the power LED turn amber and begin to flash?
- gjoynerjrJul 14, 2021Aspirant
CrimpOn wrote:
The power LED comes on GREEN? When you hold in the reset button (tiny hole) for 10-15 seconds, does the power LED turn amber and begin to flash?When plugged in and turned on the light is green. When pressing the reset button for over 15 seconds the light never changes. At no point does any light appear on the top of the router. I also checked each ethernet port; Windows said it wasn't connected to anything on each one. No wifi signal still.
