MrBTC
Aug 23, 2016Aspirant
Managing "Guest" access
Besides our "normal" SSID, I currently use one of the "guest" channels on my Netgear AC5000 for my connected house and the others for visitors. How are these needs addressed by the new Orbi?
- Dec 02, 2016
I installed the most recent update to my Orbi system and now have "Guest" access control. This resolves my issue. Thanks, Netgear, for addressing this concern.
jagreedo
Sep 28, 2016Aspirant
I, too, just installed my new Orbi Router and Satellite. I am happy with the ease of setup and its great coverage and performance, but also very disappointed with the lack of any way to have a "guest" account for friends. I am really unhappy this common feature is missing. As a workaround, I am planning to connect my old router to the satellite in the living room and use that for my guests, but that is a jury-rigged setup that shouldn't be necessary after spending $400 on a high-end router/satellite pair. It's sort of like buying a Mercedes-Benz and discovering there are no passenger seat airbags. For the price, it ought to be there.
- TheEtherSep 28, 2016Guru
You shoud understand that a jury-rigged setup (connecting a router into the Orbi system) is not going to provide you with a secure, isolated guest network. Your guests will have full access to your home network.
- jagreedoSep 28, 2016Aspirant
Thank you for letting me know. I had assumed that if I plugged my old Linksys E1000 into a port on the Orbi Satellite and created a "guest" account on it for my visitors to use, it would restrict their access to files and peripherals. Do you know of a reasonable workaround, or should I consider exchanging the Orbi for a router with a guest account feature.
- dpdurstSep 28, 2016Luminary
There is no other option at this time. Put a router in for guest access (does nothing since you still have access to the Orbi network) or wait to see if they actually come out with an update like they say. The bad thing is no commitment to any time this year or next, just a future update is all that is being said.
You may be able to go modem to old router and the Orbi in ap mode? And use guest account on the old router but still it's back to the point of paying $400 and having to use your old hardware for a feature that should have been available at release.
IMO just being told that gets under my skin.
