MrBTC
Aug 23, 2016Aspirant
Managing "Guest" access
Besides our "normal" SSID, I currently use one of the "guest" channels on my Netgear AC5000 for my connected house and the others for visitors. How are these needs addressed by the new Orbi?
- Dec 02, 2016
I installed the most recent update to my Orbi system and now have "Guest" access control. This resolves my issue. Thanks, Netgear, for addressing this concern.
Pesto242
Nov 25, 2016Star
Guest Network is working for me with v1.4.0.16!!!!
- thetalmNov 26, 2016Aspirant
where did you download v 1.4.0.16 ?
netgear support site still allow download of 1.3.0.26...
(i'm still waiting to buy Orbi until i'm sure guest network is available in firmware for EU/Italy)
- k9kidsNov 26, 2016Guide
Logged into my Orbi account and saw that a new update was available. 1.4.0.16
This update includes Guest access. Set it up and it works like a champ. I'm happy now.
just placed order on Amazon :smileyvery-happy:
- HoffNov 27, 2016Aspirant
thetalm, download the 1.3.0.26. I couldn't find the 1.4.0.16 either, so I went ahead and updated to 1.3.0.26 since I just unboxed my orbi and was running firmware 1.1.x. When the 1.3.0.26 finished installing, the Orbi said that it was on firmware version 1.4.0.16 and there was an option to enable guest account. I guess Netgear has some issues with version naming. So just DL the 'latest' update on the Netgear site http://downloadcenter.netgear.com/ (search for rbr50 and go with the 1.3.0.26 update), extrct the .img file from it and install using the "manual update" process on orbi and it will do the rest. You have to also download the rbs50 firmware seperately to update the satellite using the same process. Hope this helps, and hope that all the users on this thread stop complaining about their guest account now. IDK why it was such an issue. If you have a guest in your home, then you likely trust the guest with access to your network and files: why you need a guest account is beyond me (unless you're using this in a hotel or business or something). I guess it would make sense putting them on a seperate LAN if you want to hide your stash of kiddie pron, but other than that I don't see the big deal . . . just give them access to the main SSID if you want to give them access to the internet.
- thetalmNov 27, 2016Aspirant
thank you for your suggestions. They will be useful tomorrow when i'll receive my Orbi.
As far as Guest network is concerned, at home I host several kind of guest:, close friends, relatives, occasional friends, plus other - technicians, consultants, and so on. The guest network (with a very simple and readable password) allow them access Internet only, without any access to my NAS, computers and other devices, The private network has a very strong password that would be complicated to tell to others, also because this could provide information on my password creating scheme. The isolation from my data and devices ensures also that any threat or malware hosted in my guests' devices could affect my internal network. Furthermore, this allows me to keep a less complicated security scheme in my internal devices, costing me less effort to maintain.
In brief, that's because I consider mandatory the availability of guest network fucionality in a wireless router.
