DiogoHC
Feb 21, 2022Guide
Manual firmware update
My system was connected but not in use for some time, and apparently made a firmware auto-update with the 2.7.3.22 firmware that was wrong for the satellite. I lost the satellite connection. I downlo...
Feb 21, 2022Guru - Experienced User
You need to update the RBS before updating the RBR. Keep this in mind for future updates.
What you need to do is factory reset the RBS. Wire connect a PC to the 1st satellite📡. Already have the most current FW version files downloaded on to this PC.
Wire connect 1 PC to the back of the RBS. Factory reset the RBS, wait about 5 minutes. The PC will get a IP address from the satellite📡. The RBS will be 192.168.1.250. Use this IP address in a web browser to log in to the satellites web page. Log in as admin and password. Use the satellites 📡 web page FW update feature to select the FW update file that was unpacked from the .zip file. Then factory reset and then re-sync the satellites 📡 to the RBR.
- DiogoHCFeb 21, 2022Guide
When I use the IP address in a web browser, the result is :
THE CONNECTION HAS BEEN INTERRUPTED
A CHANGE IN THE NETWORK HAS BEEN DETECTED
ERR_NETWORK_CHANGED
I'm using Windows 11.
It happens with Edge and also with Chrome.
Any suggestions?
- CrimpOnFeb 21, 2022Guru - Experienced User
I am not confident that an individual satellite will respond to DHCP with an IP address.
Any time I interact with WiFi access points that are not part of a functioning system, I set the PC to a static IP address in the 192.168.1.x range.
- DiogoHCFeb 22, 2022Guide
I appreciate you taking time to help me, but I'm not IT professional, I have NO idea what you mean.
I tried doing what Furry suggested, with the results I posted before.
Then, suspecting a conflict between WiFi and wired connection, I did a factory reset on the satellite wired to the PC, but with the PC WiFi off.
I got the reply - web address unreachable
I have no idea what to do next, I can't find NetGear support in Portugal.
I don't want to just throw away the equipment, but I have 3 satellites that don't work and 1 working router (I still had 2 unboxed satellites for my new house and I confirmed they don't synchronize either) and they were quite expensive.
Diogo
- FURRYe38Feb 22, 2022Guru - Experienced User
What is the IP address for the RBS seen on the RBRs connected devices page?
You can try this:
ERR_NETWORK_CHANGED
Any suggestions?
Hi Furry,
I haven't been able to connect the RBS after I started all the resets, but before that the IP address was 10.0.0.4
Diogo
