Chris96's avatar
Chris96
Tutor
May 11, 2020
Manual mentions orbilogin.com, which not a secure connection
While trying to solve an internet connection issue, I found a Netgear Manual for my Orbi RBR50 online. It recommends that you login with your admin user name and password on orbilogin.com. This is no...
  • x3ja's avatar
    May 11, 2020
    If you look at where orbilogin.com routes to, it should be the IP of your router - e.g.
    > ping orbilogin.com -n 1
    Pinging orbilogin.com [192.168.0.1] with 32 bytes of data
    Reply from 192.168.0.1: bytes=32 time=5ms TTL=100
    It's not actually an external IP address so your credentials are only going locally. There's no simple way for Netgear to distribute valid certificates to be used by routers as these are tied to the domain name system and, if it were to be tied to orbilogin.com, they'd have to distribute the private/secret key with all routers which would be an even worse security problem.
    The best thing you can do is use https://orbilogin.com and trust the certificate at a time you're sure your network isn't compromised. Then, if the certificate changes you'll notice. You could do this with 192.168.0.1 (or whatever IP you have it set to) but I'm not sure you'd be able to trust that cert and you could end up needing to use that IP address when connected to a different network or something.
