kilopilot
Nov 19, 2018Follower
manual switching from 2.4 to 5.0
My computer automaticly selects 2.4 G and that is so overloaded that I am only getting 10MBPS yet on my other computer using 5.0G I get 300MBPS. How can I get devices to switch to 5G manually?
OrbiPhilip
Nov 19, 2018Luminary
From This Post:
1. Enable Telnet on http://192.168.1.1/debug.htm
2. Open Terminal (or whatever your command line app is) and enter:
telnet 192.168.1.1
3. After you're connected enter the following 3 commands, pressing Return after each one:
config set wla_ssid="Whatever You Want to Call Your 5 GHz Network" config commit reboot
4. Disable Telnet on http://192.168.1.1/debug.htm
