r37890
Jun 18, 2021Follower
Manually add MAC addresses
I have recently replace my old Linksys WRT54GL (DD-WRT) with an R6700v3 for use as a wireless access point. Under the DD-WRT software, there was the capability to manually enter the addresses for MAC...
CrimpOn
Jun 18, 2021Guru - Experienced User
r37890 wrote:I have recently replace my old Linksys WRT54GL (DD-WRT) with an R6700v3 for use as a wireless access point. Under the DD-WRT software, there was the capability to manually enter the addresses for MAC address filtering. I have found the Access Control section of the Netgear setup page, but I haven't seen any method to enter the addresses of systems that I know will be attempting to connect to the router. Is there a way to add MAC addresses to the system before they attempt to connect?
Check page 49 of the User Manual:
https://www.downloads.netgear.com/files/GDC/R6700v3/R6700v3_UM_EN.pdf
