Heriberto007
Oct 12, 2019Follower
Many sites blocked when on Orbi but not on other router
When connected to the Orbi, many normal websites are unnaccesible. I get a dialog box saying the connection is not private and It asks me for a username and passoword
On top of that I cannot streem movies on my Apple TV
Please help! How can I solve this?
1 Reply
What else is on your network. Your subject says "other router". Is that on the same network as the Orbi?
It might also help if you told people what the modem is in front of this router. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router.
Having two routers on a network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR SupportApologies for all the questions. But you can help people to help you by providing the information suggested in this forum's header:
Subject (Include model number and brief summary)
Model (Recommended - Helps the community give the best answers)
Body (Include additional detail including model version, firmware, OS and environment where relevant.)They are there for a good reason.
