razzed
Mar 15, 2022Aspirant
Massive Ping Spikes
This has happened before multiple times and I'm not sure if I ended up fixing it or if the problem just went away but every 15 seconds - 2 minutes I get massive ping spikes 600+ms, browsing is unaffe...
Mar 15, 2022Guru - Experienced User
What devices do you have all connected?
What devices are you testing pings with?
- razzedMar 15, 2022Aspirant
V 2.7.3.22
I've tested pings with my computer and a laptop both wired and wirelessly experiencing the same problem on both, problem goes away when they're connected to my ISP's modem. The only devices connected to the satellite is my computer and my phone, with only a computer and a tv connected to the router.
The model of the modem is a BGW210-700
