weartolive
May 29, 2019Aspirant
Max devices connected to Orbi mini (RBK22) on 2.4GHz simultaneously
Got Netgear Orbi Mini AC2200 Tri-Band WiFi System, 2-pack (RBK22) from Costco. Have some questions.. 1. I have 10 IoT devices that only connect to 2.4Ghz, plus a few more that needs to be on the sam...
- Jun 11, 2019
i have my Orbi mini system setup and up n running for about a week now. I tapped internet input from the existing WNR4500 ethernet out but turn WNR4500's wifi off to make sure that all my internet connection will come from new router without trying to switch back and forward between two wi-fi routers, and I am happy to report that everything seems to work fine.
I have 15 devices connected to 2.4Ghz on Orbi satellie without issue. I think i will proceed to remove the WNR4500 in the next few days.
weartolive
Size of home is 3200sq-ft, two storage. The house is built rather square shape than long or odd shape. Router is in the corner of the house downstairs. Satellite is at the other corner (diagonal) of the room where router is. They are connected wirelessly. Of course, a few internal walls here and there.
Those are devices that are outside or a bit further away. All others are indoor.
2 IoT cam at outside wall
1 IoT bell/cam
2 IoT devices at garage
How do I sprad them up between RBR vs RBS?
May 29, 2019Guru - Experienced User
You'll just have to connect them at there designated remote locations and see how they connect and work with Orbi.
