jhoff909
Apr 22, 2020Apprentice
Max speed with gigabit fiber
Hi - I have an Orbi RBK50v2 system (RBR50v2 + 1 RBS50v2) connectded directly to the ONT. My provider is CenturyLink and I've subscribed to gigabit fiber. They left me originally setup with their ro...
- Apr 23, 2020
Some have reported better speeds when in AP mode. Again, PPPoE seems to have problems on Orbi.
Apr 23, 2020Guru - Experienced User
Be sure to try a different wired PC to compare speeds.
50 series Orbi supports near 900Mbps speeds WAN to LAN.
Retired_Member
Apr 23, 2020https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
NOTE: A factory reset is necessary when you cannot recover your password.
