jhoff909
Apr 22, 2020Apprentice
Max speed with gigabit fiber
Hi - I have an Orbi RBK50v2 system (RBR50v2 + 1 RBS50v2) connectded directly to the ONT. My provider is CenturyLink and I've subscribed to gigabit fiber. They left me originally setup with their ro...
- Apr 23, 2020
Some have reported better speeds when in AP mode. Again, PPPoE seems to have problems on Orbi.
Apr 23, 2020Guru - Experienced User
jhoff909
May 02, 2020Apprentice
I finally got around switching to AP mode and adding the Zyxel C3000Z back in as the router. I now get 940/940 speeds wired to either the Orbi or the C3000Z. I even get decent results using the speed test function in the Orbi (850/930). Sad the Orbi couldn't hack it to do routing/nat/wifi. Oh and I even turned on ipv6 in the C3000Z which is working as well ;)
- FURRYe38May 02, 2020Guru - Experienced User
Glad its working now. Ya seen others with this model modem experience same issues with Orbi in router mode. Why I like stand alone modems.
Enjoy. :smileywink:
- boramieMay 12, 2020Aspirant
What are the steps to do this? We just switched from Spectrum to CenturyLink and I have this model modem. The way our home is constructed, the modem is in a closet, so I'd like to get the Orbis (router and 1 satellite) back in the network as access points to bolster speeds.
- jhoff909May 12, 2020Apprentice
Turn off Wifi on your "modem" (the unit centurylink provided). Change your orbi to AP mode (advanced tab, advanced setup, router/ap mode). Connerct one of the ethernet ports of the CL "modem" to the WAN port of your Orbi
boramie wrote:What are the steps to do this? We just switched from Spectrum to CenturyLink and I have this model modem. The way our home is constructed, the modem is in a closet, so I'd like to get the Orbis (router and 1 satellite) back in the network as access points to bolster speeds.
So that will effectively kill the wifi networks on the combo unit and make my old wifi network on the Orbi visible again?
- FURRYe38May 13, 2020Guru - Experienced User
https://community.netgear.com/t5/Cable-Modems-Routers/What-s-the-Difference-Between-a-Cable-Modem-and-Cable-Modem/m-p/1864698#M21950
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- boramieMay 13, 2020Aspirant
The ONT (I think?) is secured outside the house, the modem/router combo unit is the Xyxel C3000Z. The modem/router unit was installed in a coat closet as that is where the house smart panel is located. I don't see a way to relocate the modem/router unit, so I'm planning on putting the Orbi base station in AP mode and connecting it to the LAN port on the Zyxel and putting a satellite where the base station originally was once some extension cords arrive.
