jhoff909
Apr 23, 2020Apprentice
Max speed with gigabit fiber
Hi - I have an Orbi RBK50v2 system (RBR50v2 + 1 RBS50v2) connectded directly to the ONT. My provider is CenturyLink and I've subscribed to gigabit fiber. They left me originally setup with their ro...
- Apr 23, 2020
Some have reported better speeds when in AP mode. Again, PPPoE seems to have problems on Orbi.
May 13, 2020Guru - Experienced User
https://community.netgear.com/t5/Cable-Modems-Routers/What-s-the-Difference-Between-a-Cable-Modem-and-Cable-Modem/m-p/1864698#M21950
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
boramie wrote:What are the steps to do this? We just switched from Spectrum to CenturyLink and I have this model modem. The way our home is constructed, the modem is in a closet, so I'd like to get the Orbis (router and 1 satellite) back in the network as access points to bolster speeds.
boramie
May 13, 2020Aspirant
The ONT (I think?) is secured outside the house, the modem/router combo unit is the Xyxel C3000Z. The modem/router unit was installed in a coat closet as that is where the house smart panel is located. I don't see a way to relocate the modem/router unit, so I'm planning on putting the Orbi base station in AP mode and connecting it to the LAN port on the Zyxel and putting a satellite where the base station originally was once some extension cords arrive.
- FURRYe38May 13, 2020Guru - Experienced User
Ya thats a modem router combo. AP mode should help your configuration.
boramie wrote:The ONT (I think?) is secured outside the house, the modem/router combo unit is the Xyxel C3000Z. The modem/router unit was installed in a coat closet as that is where the house smart panel is located. I don't see a way to relocate the modem/router unit, so I'm planning on putting the Orbi base station in AP mode and connecting it to the LAN port on the Zyxel and putting a satellite where the base station originally was once some extension cords arrive.
