jlewis11
Nov 03, 2020Follower
Max speeds on orbi rbr50
I recently upgraded to 1GB internet access. I have tested the download speed plugging a Lan cable into the back of the orbi router to eliminate any WIFI issues and I get between 200MBPS and 400MBPS....
Nov 03, 2020Guru - Experienced User
On wireless, 400-500Mbps depending upon wifi mfr design and support.
On wired, you should see near 900Mpbs:
