alanfca
Aug 27, 2016Guide
Maximum Number of Connections supported by Orbi?
What are the maximum number of simultaneous wifi connected devices supported?
mdgm-ntgr
Sep 02, 2016NETGEAR Employee Retired
This does depend on what you are doing with those devices, which Wi-Fi standards they support etc.
It can handle a large number of devices simultaneously.
How many devices would you want to connect wirelessly to the Orbi at once?
- alanfcaSep 02, 2016Guide
Would be on 802.11 n and ac devices
Would 40 to 50 devices be within spec?
Thanks
- DarrenMSep 07, 2016Sr. NETGEAR Moderator
Hello alanfca
You may want to check out this KB.
http://kb.netgear.com/app/answers/detail/a_id/31097?cid=wmt_netgear_organic
DarrenM
