Stubbzbeast
Jun 14, 2020Aspirant
Maximum number of Orbi RBS20 Satellites I can add
Can I add another satellite? I currently have and RBR20 router with 3x RBS20 satellites connected through the house.
- Jun 22, 2020
Thanks for your advice.
Jun 15, 2020Guru - Experienced User
How big is this house? SQ Feet?
Having too many RBS may over saturate your home and the system and become problmatic.
30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
- StubbzbeastJun 15, 2020Aspirant
FURRYe38 wrote:How big is this house? SQ Feet?
Hi Furry.
Thanks for your reply. My house is two storey, approximately 450 square metres per storey. That's about 1,480 square feet per storey.
I currently have 3 satellites but a a result of walls and floors one of the satellite's strength is yellow, the other two are green. The router is upstairs at one end of the house with one of the satellites upstairs at the other end of the house. downstairs the two satellites are at opposite ends of the house. There's two brick walls that signal has to get through within the house.
Any extra thoughts or comments? I'm happy to get another satellite, if it's safe to do so.
- FURRYe38Jun 16, 2020Guru - Experienced User
You may want to look into wire connecting the RBS via eithernet or use PowerLine adapters to help the RBS use a wired backhaul vs wireless due to the brick in the house being a factor.
- StubbzbeastJun 22, 2020Aspirant
