Stubbzbeast
Jun 14, 2020Aspirant
Maximum number of Orbi RBS20 Satellites I can add
Can I add another satellite? I currently have and RBR20 router with 3x RBS20 satellites connected through the house.
- Jun 22, 2020
Thanks for your advice.
Jun 16, 2020Guru - Experienced User
You may want to look into wire connecting the RBS via eithernet or use PowerLine adapters to help the RBS use a wired backhaul vs wireless due to the brick in the house being a factor.
Stubbzbeast
Jun 22, 2020Aspirant
- FURRYe38Jun 22, 2020Guru - Experienced User
Good Luck
