Smouritsen's avatar
Smouritsen
Measured speed on RBS23 setup
Hi My setup is Cable 1000/100 to FAST3890V3 modem/router ->Cat6 cable->RBR20 (basement)->wireless (daisychain)->RBS20 AP mode (gnd floor)->RBS20 (2nd floor). All units updated to FW 2.6.2.104 With ...
  • CrimpOn's avatar
    Feb 14, 2021
    Smouritsen wrote:
    With wired Macbook to RBR20 I measure approx 750Mbps, on first RBS20 I measure approx 425Mbps and on 2nd floor RBS20 I measure approx 145Mbps.
    On the webpage of RBR20 I see good 5GHz backhaul connection on both satellites. Is the measured speed drop normal - seeing roughly half at each RBS in the daisy link?
    Daisy chain will reduce overall throughput because each packet has to be sent twice, once to satellite 1 and again to satellite 2. The response, "I got it, send another one" has to go through two hops on the way back. Changing the Orbi from AP to router mode would make little difference.
    As an 'aside', it is the RBR20 that is in AP mode, not the RBS20.  "mode" has no meaning to satellites. they are always access points only.
