nibaz's avatar
nibaz
Follower
Aug 31, 2017
Megasat SAT>IP Server 3 with Orbi
I have a Megasat SAT>IP Server 3, it was connected via ethernet cable to my DSL modem/router (Fritzbox) which then broadcast the TV signal through the router's WiFi. Now I have a hooked up an Orbi system and deactivated the WiFi of the DSL modem/router. I tried connecting the Megasat IP Server to the Orbi ethernet pörts but I cannot see the IP Server on my network. Has anyone got a SAT>IP server working with the Orbi along with a DSL modem?
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello nibaz
    Do you have the modem bridged? if not are you running orbi as a access point?
    DarrenM
