MFlair
Jan 19, 2024Aspirant
Merge 2 RBR50 Sytems
I have 2 pairs of orbi systems with main + satellite. I want 4 access points. The second main router will not set up as a satellite to the first main. I assume it is because it is not a satellite. Do I need to set up the second main router as another wi fi source if so, how?
First off:
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️Can't use the 2nd RBR as a RBS, it could work as a wired AP in AP mode however would not be integrated into primary system. Would be 2ndary AP using different SSID name and channels.
- MFlairAspirant
Thanks - that helps. I don't have hard wiring upstairs where I need it, so no way to set up as a secondary AP. I guess my other option is to purchase another satellite to add to system 1. Not sure if I can still get the RBS model (about 5 yrs old). Any idea if new models are compatible or should I start over with a new mesh network?
I have a 2 story 3600 sf with large garage.
1500 sf basement
1500 sf main level
600 sf upper level
For that size of home, you'd only need the main router and two RBS. Anything more then that would start to cause problems and over saturate the home with too much wifi:
