WouterNLD
Dec 23, 2016Tutor
MESH currenty or on roadmap
Hi all, Currently I am delaying my purchase due to the Orbi not being a MESH system, but a 'star' system. Since I am not able to place the router in the middle of my home, but I am convinced Orbi...
- Dec 24, 2016
WouterNLD wrote:
What I understand is that a true MESH within the Orbi system is not available nor confirmed, but requested.Correct, but in most homes the star topology we use will give a better outcome than using mesh.
One Orbi router with one Orbi satellite can cover a very large area in most homes with high performance dedicated backhaul between the router and satellite.
We can't comment on what we may/may not have planned, but customer feedback (e.g. via the Idea Exchange) is important to us in helping us to decide where to focus our efforts.We have already added some popular requested features such as guest wi-fi.
RonV42
Dec 24, 2016Luminary
Yes that is a issue with brick construction and some of the older plaster homes. Wifi is almost impossible to go room to room. Orbi may not be the choice for this purpose. I have a friend that had to go back to the central router only and then backhaul ethernet access points to get the coverang. He lives in a really large and older home and it took 8 AP's to account for the coverage we wanted. Each solution has it's pluses and minuses. Orbi seems to account for moden 2 to 4,000 SqFt housing builds.
Ely
My home is totally made out of bricks and this is the first system that gives me consistent 90/MBps down 12MBps Up ALL the way from the front of the house to the backyard, I'm talking Internet speeds (which is what I pay Comcast for) the actual transfer speeds between devices is much more greater than that, I tell the OP try Orbi if you haven't yet and see for yourself, if you don't like it you can always return it, nothing to loose.
