JohnAlmond
May 10, 2021Follower
Mesh Network
I'd like to build a mesh network to cover rooms with low singal but also have "advanced features" such as VPN, DynamicDNS among others. I was thinkingin in using Nighthawk RAX40 WiFi 6 connected ...
May 10, 2021Guru - Experienced User
Only EX series wifi extenders are compatible with RAX routers.
Something to post about in the RAX forum to get help on this particular model router:
Extenders forum:
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders
Good Luck
any of netgears extenders will work with the RAX routers.
But if you're wanting the extender to support wifi 6, then you'd need a EAX extender.
That'd be the EAX80, EAX20, EAX18, EAX15
