DTR1065
Aug 01, 2019Follower
Mesh or relay?
Does each satellite serve as a relay to the next satellite therefore each one sends out a signal or does each satellite only receive a signal from the modem?
Aug 01, 2019Guru - Experienced User
MESH and RBS works as extenders to extend the wifi signal from the main RBR router. If daisy chain is enabled then the RBS can piggy back off one another if placed in a line out from the RBR.
