Elisa2414
Jul 05, 2020Tutor
Mesh RBK752 or RBK50
I need to replace the useless router provided by my cable company. We have a large home running many devices. It is not a smart home, but my daughter is a gamer. I'm not a techie so torn between Orb...
Jul 05, 2020Guru - Experienced User
https://www.netgear.com/orbi/default.aspx
https://www.netgear.com/orbi/wifi-systems.aspx
https://kb.netgear.com/000038220/What-are-the-hardware-specifications-of-the-available-Orbi-WiFi-Systems
Can you take advantage of AX wifi or just future proofing?
30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Elisa2414
Jul 05, 2020Tutor
My home is 3000 sq ft, outside walls are concrete block and inside is wood frame. I can accommodate the 30 feet. The WiFi 6 AX4200 it the top of my budget. We do have several items connect there are 4 ppl each with phones, iPads, several computers now that we work from home, Android tv boxes, fire stick, tiki security camera. My daughter also uses Xbox and ps4. Our current Equip just can’t keep up. Shout spend the $100 more for the RBK752.
- FURRYe38Jul 05, 2020Guru - Experienced User
If it's something you can afford, it's worth trying it out and see how it works for you. The 1 RBR and 1 RBS should be plenty for your size of home.
- CrimpOnJul 05, 2020Guru - Experienced User
This is (yet another) example of options available to Costco members (besides the cheap rotissery chicken).
Amazon has the RBK752 (1 plus 1) for $449US and does not show an RBK753. Costco sells the RBK753 for $499US.
Spend $50 to (a) allow for unusual building shape or materials, (b) provide a spare in case one satellite is enough but fails after 1 year, or (c) sell on eBay for a LOT more than $50.
You may want WiFi in the back yard (where we all seem to be spending a lot of time these days) and find that the concrete block walls make for horrible coverage. Put that spare satellite in a window facing the outside and, voila, WiFi outside!
There food is good. :smileywink:
