AKDude
Nov 03, 2019Aspirant
Mesh system generic question
I currently have an Arris 7580 AC router that has served my purposes until now. I recently added a Simplisafe doorbell with camera, which I could not get to connect to my router. The problem is the d...
- Nov 03, 2019
Plus, almost every mesh WiFi system acts the same way (Google, Deco, Velop, etc.)
CrimpOn
Nov 03, 2019Guru - Experienced User
As FURRYe38 said, Netgear's Orbi satellites can connect directly to the router, and can also "Daisy Chain" off another satellite. A top of the line three unit RBK53 Orbi package will set you back $400 plus tax. The RBK23 would be $270 plus tax. Dumping the Arris in favor of a mesh system is not cheap.
As you have found, for a WiFi "extender" to function, it has to be close enough to the router to get a good signal. The same is true for Orbi satellites. Another solution is to make use of existing coax or electrical wiring to create a wired network. If there is coax throughout the townhouse, a pair of MoCHA adapters can create a network allowing you to place a WiFi access point wherever there is coax. Likewise, Powerline adapters can allow you to place a WiFi access point wherever there is electricity.
What a frustrating situation. I, also, have Simplisafe, but my doorbell points "sideways" at the front door. No video of people walking up to the door for me!
