jag288
Aug 13, 2019Aspirant
Mesh vs. Access Point
 Just setting a new system with a router in my basement and satellites on the ground and second floors. There is hardwired ethernet from the ground floor and second floor to the basement running into ...
Aug 13, 2019Guru - Experienced User
AP is recommended if you already have a host router in front of the Orbi system.
You can use the host routers DMZ for the Orbi if you want to try the Orbi in router mode.
What is the mfr and model # of the switch being used?
