Jaystill29
May 26, 2021Follower
Mesh wifi
Is the nighthawk Triband WiFi 6 ax3600 better than the orbi rbk752
May 27, 2021Guru - Experienced User
Are you talking of comparing the MK83 system to the RBK752 system?
the MK83 uses at 1800mbps backhaul with a 1200/600mbps front haul
the RBK752 uses a 2400mbps backhaul with a 1200/600mbps front haul
both have the same ethernet ports.
RBK752 is based on the orbi firmware
MK83 is open mesh based.
Basically it comes down to what you prefer.
