jkillean's avatar
jkillean
Follower
Dec 08, 2019
Micro Segmentation with Orbi RBR50
Can RBR50 plus satellites be set up with micro Segmentation to isolate my SmartThings network?  If so, how? If not, is the newest ORBI better suited?
  • CrimpOn's avatar
    CrimpOn
    Honestly, after using Google to find information on "micro segmentation", I learned almost nothing.  "Better than firewalls, VLANs, Access Control Lists."  Wow!  But, what IS it?  No idea.
    Orbi does not support internal firewall rules or internal VLANs, and has only a primitive "yes/no" access control.  I think there is zero chance that this "wonder technology" is supported by ANY residential class WiFi router.
    If the goal is to prevent someone who compromises one IoT device from using it as a platform to attack other devices on the local network, then the Guest network appears to be the only mechanism offered on the Orbi platform (and most other residential WiFi routers).  The "Help" found at the bottom of the Orbi Guest setup screen does not exactly match the current choices, so I am not 100% certain of how Guest devices are controlled.  From reading the setup screen the choices are:
    • Guest devices can access only the Internet.  Not any other devices.  Not on the primary network.  Not on the Guest network.
    • Guest devices CAN access the primary network, Guest network, and Internet.
    Thus, a device connected to Guest is pretty much "isolated".  If someone compromises an IoT device, they can attack the Internet, but not me.
    You can ask on the Orbi WiFi 6 forum if that product has more advanced features: https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
      • SW_'s avatar
        SW_
        Prodigy
        ekhalil wrote:
        An additional functionality in Orbi AX is that the guest network has its own subnet that is different than the subnet of the main network.
        It would be nice if this feature will trickle down to non-AX Orbi in future FW update.
