jerrodbug
Jun 05, 2019Aspirant
Migrate AC200 settings to AC3000?
I bought the AC2200 with 1 satellite, and am considering returning it, and getting the AC3000 2 pack instead. Can i backup the settings on the AC2200 and restore them to the 3000 so i dont have to s...
- Jun 05, 2019
You need to set up the AC3000 from scratch. Loading a saved config file from a different model Orbi is not supported.
Jun 05, 2019Guru - Experienced User
Needs to setup from the beginning. Then save off a new back up config to file.
- jerrodbugJun 05, 2019Aspirant
I do already have the AC2200 fully setup exactly how i want. Your saying i would need to setup the AC3000 from scratch? I would think the software/firmware would be the same on both devices. Or are you saying that i would need to setup the AC3000 from scratch, but could then load the config file from the AC2200 with the settings i want?
- FURRYe38Jun 05, 2019Guru - Experienced User
