jerrodbug's avatar
jerrodbug
Migrate AC200 settings to AC3000?
I bought the AC2200 with 1 satellite, and am considering returning it, and getting the AC3000 2 pack instead.  Can i backup the settings on the AC2200 and restore them to the 3000 so i dont have to s...
  • FURRYe38's avatar
    You need to set up the AC3000 from scratch. Loading a saved config file from a different model Orbi is not supported.
