jerrodbug
Jun 05, 2019Aspirant
Migrate AC200 settings to AC3000?
I bought the AC2200 with 1 satellite, and am considering returning it, and getting the AC3000 2 pack instead. Can i backup the settings on the AC2200 and restore them to the 3000 so i dont have to s...
- Jun 05, 2019
You need to set up the AC3000 from scratch. Loading a saved config file from a different model Orbi is not supported.
Jun 05, 2019Guru - Experienced User
Also be aware that if you get a new AC3000, the FW version maybe old v1x, You first need to download v2.0.0.74 and apply to the RBS first then RBR, then you can upgrade to v60 which is the latest. This is only if the new system is on old v1 FW version.
Good Luck.
