fmalloy
Jun 04, 2020Luminary
Minecraft - Connection Lost - Timed out Connecting to Minecraft Server
New RBR20. Connecting to a friend's Minecraft server, initially connects to the server, and the game starts ok as normal. About 5 seconds later - "Connection Lost" and "Timed Out". Computer is connec...
fmalloy
I have the latest firmware.
I don't know the internet provider's modem (it's a small Internet provider using Wi-Fi microwave dish on the roof and the modem is in the attic) nor do I know why this matters. My internet has been rock solid.
I do not have Armor or Circle enabled.
Mikey94025
Jun 04, 2020Hero
If Minecraft requires port forwarding, then swapping out your router will change things like the computer's LAN IP address. Port forwarding rules must be setup on the Orbi like they were on the R7000. Or perhaps you're relying upon UPnP to set these rules up for you automatically. Note the IP address of the computer and ensure that the port forwarding rules are correct for the outside port and the internal computer IP.
Another problem may be that your Windows host is treating the new wireless network as Private whereas your old wireless network was set to Public. Even though you named the wireless SSID the same it will be a different Windows network (connection). If Private, then the port will be blocked by the Windows firewall.
In short, setup port forwarding again and use tools like https://canyouseeme.org/ to verify that the port is visible on your computer to the outside network.
