kochin
Jun 23, 2019Apprentice
miniupnpd doesn't update total bytes sent/receive
I tried to get router traffic information from my Orbi RBR50 using it IGD feature. When I ran the upnpc program to retrieve information, I found the total bytes received and sent never get updated an...
Jun 24, 2019Guru - Experienced User
Please file a support ticket here and give all details and debut logs to them for review:
https://www.netgear.com/mynetgear/registration/login.aspx
Thank you.
kochin wrote:I tried to get router traffic information from my Orbi RBR50 using it IGD feature. When I ran the upnpc program to retrieve information, I found the total bytes received and sent never get updated and stay at 4294967295 while the total packets sent and received get updated as expected.
d:\Downloads\win32-miniupnpc-2.1>.\upnpc-shared.exe -s -m 192.168.0.1 upnpc : miniupnpc library test client, version 2.1. (c) 2005-2018 Thomas Bernard. Go to http://miniupnp.free.fr/ or https://miniupnp.tuxfamily.org/ for more information. List of UPNP devices found on the network : desc: http://192.168.0.1:5555/rootDesc.xml st: urn:schemas-upnp-org:device:InternetGatewayDevice:1 Found valid IGD : http://192.168.0.1:5555/ctl/IPConn Local LAN ip address : 192.168.0.2 Connection Type : IP_Routed Status : Connected, uptime=5466s, LastConnectionError : ERROR_NONE Time started : Sun Jun 23 20:10:35 2019 MaxBitRateDown : 1000000 bps (1.0 Mbps) MaxBitRateUp 1000000 bps (1.0 Mbps) ExternalIPAddress = xx.xx.xx.xx Bytes: Sent: 4294967295 Recv: 4294967295 Packets: Sent: 25029827 Recv: 71936774Orbi runs a version of miniupnpd which is supposed to provide those information. It appears the miniupnpd in the firmware is buggy. Netgear, please have your developers take a look. Thanks.
- kochinJun 24, 2019Apprentice
FURRYe38Thank you for responding.
Unfortunately, my 90 days support had expired months ago. I don't see a way to submit bug reports without having a valid support contract with Netgear.
I can only hope someone from Netgear is monitoring its community site and will forward the issue to their development team.
- FURRYe38Jun 24, 2019Guru - Experienced User
Please send a PM to Blanca_O and Christian_R and see if they can help pass this on to NG engineering. Be aware that even though you report it to NG, it may not get changed, if at all or will take a while for it to appear, even it it does get changed. If miniupnp is working over all and the report function isn't working, maybe something that NG may not look into that much. Just saying. Hope it will get looked at.
Good Luck.
- schumakuJun 24, 2019Guru - Experienced User
FWIW: The UPnP information available is about the WAN (Internet) interface - however the UPnP AV/DLNA miniupnpd is intended to be run on the same broadcast domain, so the local [W]LAN only.
