kochin
Jun 23, 2019Apprentice
miniupnpd doesn't update total bytes sent/receive
I tried to get router traffic information from my Orbi RBR50 using it IGD feature. When I ran the upnpc program to retrieve information, I found the total bytes received and sent never get updated an...
kochin
Jun 24, 2019Apprentice
FURRYe38Thank you for responding.
Unfortunately, my 90 days support had expired months ago. I don't see a way to submit bug reports without having a valid support contract with Netgear.
I can only hope someone from Netgear is monitoring its community site and will forward the issue to their development team.
Jun 24, 2019Guru - Experienced User
Please send a PM to Blanca_O and Christian_R and see if they can help pass this on to NG engineering. Be aware that even though you report it to NG, it may not get changed, if at all or will take a while for it to appear, even it it does get changed. If miniupnp is working over all and the report function isn't working, maybe something that NG may not look into that much. Just saying. Hope it will get looked at.
Good Luck.
