kochin
Jun 23, 2019Apprentice
miniupnpd doesn't update total bytes sent/receive
I tried to get router traffic information from my Orbi RBR50 using it IGD feature. When I ran the upnpc program to retrieve information, I found the total bytes received and sent never get updated an...
schumaku
Jun 24, 2019Guru - Experienced User
FWIW: The UPnP information available is about the WAN (Internet) interface - however the UPnP AV/DLNA miniupnpd is intended to be run on the same broadcast domain, so the local [W]LAN only.
kochin
Jun 27, 2019Apprentice
schumaku wrote:FWIW: The UPnP information available is about the WAN (Internet) interface - however the UPnP AV/DLNA miniupnpd is intended to be run on the same broadcast domain, so the local [W]LAN only.
Yes. For anyone who is interested, you can visit http://<your router ip>:5555/WANCfg.xml and see what actions your router can respond to.
- schumakuJun 27, 2019Guru - Experienced User
Oh sorry, I have mixed up the minidlna with the miniupnp 8-)
