kochin
Jun 23, 2019Apprentice
miniupnpd doesn't update total bytes sent/receive
I tried to get router traffic information from my Orbi RBR50 using it IGD feature. When I ran the upnpc program to retrieve information, I found the total bytes received and sent never get updated an...
Jun 24, 2019Guru - Experienced User
Please send a PM to Blanca_O and Christian_R and see if they can help pass this on to NG engineering. Be aware that even though you report it to NG, it may not get changed, if at all or will take a while for it to appear, even it it does get changed. If miniupnp is working over all and the report function isn't working, maybe something that NG may not look into that much. Just saying. Hope it will get looked at.
Good Luck.
kochin
Jun 27, 2019Apprentice
Thanks for the suggestion. I've sent a message to them.
FURRYe38 wrote:Please send a PM to Blanca_O and Christian_R and see if they can help pass this on to NG engineering. Be aware that even though you report it to NG, it may not get changed, if at all or will take a while for it to appear, even it it does get changed. If miniupnp is working over all and the report function isn't working, maybe something that NG may not look into that much. Just saying. Hope it will get looked at.
Good Luck.
- FURRYe38Jun 27, 2019Guru - Experienced User
Let us know if you find out anything.
